Terex that might need a little work
crane operator
sw missouri
Take the crane off and make it in to a dump truck
A lot of states- mine is one- the truck cranes don't have plates- because they don't have titles. Some states they are titled, and have plates.
In my state- they are considered "Special Mobile Equipment" and don't fall under the regular classification. I could about imagine that DOT officer conversation with a dump bed on it. :)
Honestly- the thought of it as a dump truck never crossed my mind. They are only a 8.3 cummins, and it would be a lot of work, and tough to sell to someone else. The frame is all a welded box beam, and pretty rigid.
But you could weld in a rear hinge plate in where the rear boxes are.
Its actually probably worth the most in parts, but it would take you forever to sell them. Outriggers, tele cylinder, winch, LMI box, engine trans rears, block and ball. I think the upper cab glass may be getting hard to get- its a flat piece that actually curves on to the lower front glass. With terex gone- I don't know if you could get them from load king or not.
Operational
  • Boom
    • Telescopic
  • Boom length: 94'
  • Sections: 3
  • Maximum lift capacity: 80,000 lbs"
Liars! I only see two sections of boom there :D
find an RT with shot running gear and make a frankencrane.
icestationzebra
I've seen a truck with an excavator mounted on the back a couple of times around MKE. (Wasn't a Gradall, might have been a Deere?) I've always wondered what they used it for as the applications have to be fairly limited. But I could see this chassis making a great mount for something like that. ISZ
Tyler d4c
Salix Pa
It's a deere 80 on a chevy it's been for sale for years. If it's the one I've seen that is.
Tony Wells
Tyler, TX
HogZilla Keeper
Crane operator....you said Terex is gone...As in out of business, or sold out? I have two to repair, so looking for some tech docs and likely a few parts. They both have Greer instrumentation, one of which seems a bit flakey and I have no manual on it either. I'm not a crane specialist, but the owner was told there was a simple switch failure on one of them that prevented the boom from retracting once it was extended. Friday I played with it a little and had no problem with that, but somehow I got the thing boomed up and telescoped out and could not get it back down. Maybe that switch does have a problem. The Greer unit was telling me things I didn't understand, like "Exclusion Zone" and "Overload". I had nothing on it but the block. Somehow I need to find some books on this thing. Well two of them. One is an RT 230 and the other a CD 225. Naturally the owner wanted them fixed to use over the weekend. I said NO before even looking at them. He had an old time crane op come look at them a while back and he said they were in pretty good shape. Last inspected in June 2020. But they came from Purple Wave, like the above example. Just walking around them they don't seem to be too bad, but cranes aren't my thing. I do see they have some safeties built in that disable certain functions at unsafe positions. That I like, unless they end up stuck like that one did Friday. Took a while to figure out how a certain safety functioned and defeat it just to bring it down. We were supposed to get some bad weather and I didn't want to leave a lightning rod sticking up in the air.
crane operator
sw missouri
Terex no longer builds any cranes in the U.S. They shut down the factory and left all the dealers hanging. Load king out of kansas city took over the truck crane and boom truck lines, but not the RT lines. Greer - some of it is available- some isn't, but there are aftermarket solutions available- just not very cheap. A full LMI (load computer system) could set you back $10,000- if you have to retro fit a new system.
If I was stuck needing help- parts or books- load king out of kansas city is where I would start.
Tony Wells
Tyler, TX
HogZilla Keeper
I saw where Terex abruptly shut down their Waverly facility and moved everything to OK back in 2016, and Terex has a sizeable web presence ( https://www.terex.com/ ), but after trying to contact them through their customer service dept and being totally ignored I sensed a problem.
I'll look into Load King and see if I can get some assistance. Thanks for the reference. Supposedly Scott Macon Equipment up in DFW is a dealer for the RT line, so I may try them again. I no response from them yet.
crane operator
sw missouri
Scott macon was a terex crane dealer, and terex was always hard to get parts from. I know a lot of the dealers were upset when they closed the new oklahoma facility, and the dealers were stuck with brand new cranes to sell, that no one wanted- because they were now a dead line, with no support.
I would hate to know how much $$ they wasted in the move from waverly to oklahoma, but the only one that made $$ on that was the VP that got promoted for making it happen.
Terex in the last year or so has tried to re enter the North American market- they still build a RT in Italy, and they were not very well received in the US. Too many people left hanging last time.
Load king is going to be your best bet- they've got new stuff they want to sell- Scott Macon can't get any parts from terex, so it would only be stuff they have left on their shelves- which probably isn't much.
Tony Wells
Tyler, TX
HogZilla Keeper
Oh boy! Sounds like my kind of fun! From what I've been told, this switch, that disables the boom retract under certain conditions (assuming I can locate and test it), is probably a popular wear part and isn't likely to remain on the shelves. I'd bet I'm going to strike out. Hopefully, Greer is used on more than Terex equipment and if I really need some help with it I will have better luck. Just got started at 1:00 Friday, so don't know much about it yet. Took a it just to get it started and the swing brake to release. It has been sitting for at least a couple of years since the auction. I probably would have voted against it if I had known about Terex.
Not being a crane guy, I had no idea of what was going on with Terex. I also have artic offroad dumper in the yard. It will probably sit for a while now.
Thanks, crane operator
crane operator
sw missouri
Typically, there's nothing electrical from the lmi that will stop the crane from retracting- the LMI will stop boom down, cable up, and telescope out- all to stop overload. There's typically nothing to stop boom up, cable down, and telescope in from the LMI.
That's not to say that there isn't a solenoid control for pilot pressure that has to work for individual functions in either direction, if its a pilot or electric over hydraulic machine. If its electric over hydraulic joysticks, it could be a joystick issue.
Either way- it shouldn't be anything exotic- Terex wasn't making the valve stacks themselves, so you should be able to source the solenoids without too much trouble.
If it is the LMI shutting you down, you should be able to work around the system by 12v bypassing the signal shut off. Of course the LMI won't turn you off for any overload conditions with it bypassed, but it would get you running.
