Russ
Hello,
Can anyone tell me if the engine water pump on a 82-40 is different than the water pump that is used in a truck engine application? I mean different as in higher gpm, and able to work against a higher head pressure as the radiator on the 82-40 is behind the operator verses right in front of the engine as in a truck application.
Thank you for your time,
Russ
Russ
