Benjamin Herd
Good evening, I came home from work today and was getting ready to hope on my TD7E and clean out some underbrush when I noticed my left track tension was a little loose. I fired the dozer up to let it warm and grabbed the grease gun to tighten the track. I tightened it up and put the cap on. When I came back to get on it I noticed the tension had slack in it again. I grabbed the grease gun again and noticed that I had grease comminout from behind the fork and the track would not tighten. I've looked in the computer to see if my dozer had a master link or pin and I can't find any info anywhere! Any help would be greatly appreciated. This will be my first attempt to split the tracks as well as fixing the track tensioner. So any and all help, pointers or whatever you can say to help will be greatly appreciated.
My serial # is. 441002U009869
Thank you
Thank you
