I am working on a 20e that is driving me nuts as i said the clutch pr.is normal cold but when it gets hot 1/2guage the clutch pr.drops to to100 psi, now here is the strange part it does it in all gears and the main pressure holds normal 275psi so iam thinking modulator valve but i have replaced the springs in it and same thing.I have had leaks on sealing rings and clutch piston seals before but never seen a leak inside effect every speed in both directions this way. :Banghead
Thanks for any help.
