Td20c repower in progress
Discussion in 'Dozers' started by illinoisboy, May 3, 2017.
  1. illinoisboy
    illinoisboy Well-Known Member
    Sep 17, 2009
    146
    contractor
    Greenup
    Pulled the 573 that was on its way out and have a 573 out of an IH 270 scraper to put in it. Problem is, my dozer is a vpump. And the donor motor is a rotary, stanadyne pump. The stanadyne pump is locked up and junk. I can't find a reasonable price on a reman one. Any leads on a used one? Or anyone who has a rotary pump off a ,573 that they would part with? I just had the torque converter rebuilt, and don't have an engine to put in front of it now. Looks like it's not possible to change pumps either,,, front cover and gears are way different. The newer 20s ran an 8.3 Cummins, but I'm not sure about the bell housing,flywheel working with existing TC. Supposedly the same TC they used up until the late 90s.. any help would be awesome! Also thought about a 466 IH, but would prefer the Cummins
  2. DB09
    DB09 Active Member
    May 15, 2016
    38
    Statesville NC
    Try fp smith in California.
  3. repowerguy
    repowerguy Senior Member
    Mar 19, 2015
    675
    mixer truck mechanic
    United States southern Ohio
    The newer TD-20's had L-10's in them, 15E's had 8.3's in them.
    illinoisboy likes this.
  4. RZucker
    RZucker Senior Member
    Jul 7, 2013
    4,102
    Mechanic/welder
    Wherever I end up
    You need to do some research. I know nothing about the 573... But the scraper engine is more than likely equipped with a fast acting limiting speed type governor whereas the crawler would prefer a constant speed type governor. You may want check into that before you grab the first pump you find. Seen that issue a few times when people bought a 2 stroke Detroit to power a crawler and the limiting speed governor from a truck would just not run right. At least that was a simple parts swap. Your pump may not be so easy... Just sayin'
  5. RZucker
    Jul 7, 2013
    4,102
    Mechanic/welder
    Wherever I end up
    The 20's I worked on had the V-800s.
  6. repowerguy
    Mar 19, 2015
    675
    I'm not sure of the series of the TD-20, I'm thinking it was a E series that had the L-10 in it RZucker. Regardless, a 6v92 would be a real repower, with the aforementioned dual weight variable speed governor of course!
  7. RZucker
    Jul 7, 2013
    4,102
    Mechanic/welder
    Wherever I end up
    Actually my Detroit comment was related to Terex/Euclid crawler owners, But a 6V92 would make an excellent replacement for a V-800.
  8. illinoisboy
    Sep 17, 2009
    146
    contractor
    Greenup
    It's not a v800. I get your comment about the pumps though,, that makes sense, the scraper would be pulling down pretty hard too though so not sure. A Detroit while might be great to some, wouldn't be my pick, I need something that I can match up my bell housing and TC with. The 466, 8.3, and l 10, all were at one point mated to the same Rockford TC I have in it now. Just not sure the 466 will be enough... Talked to guys who have repowered with a 466, and it's worked for them... Thanks all!
  9. oldirt
    oldirt Senior Member
    Apr 22, 2009
    504
    iowa
    I vote for the 8.3. no way would I want to go back to the detroit (expletive deleted). cummins is a fantastic motor.
  10. Jock
    Jock Well-Known Member
    Oct 24, 2012
    55
    I used to work for the Dressta (previously Dresser, previously International) dealer back in Tassie, Oz. There were quite a few 20's running around down there. The C's and E's had V800's, the H I think had a the M11 Cummins and the latest TD20Ms had the common rail QSC8.3. By far one of the worst engines I've worked on. We had no end of dramas with injectors, leaking sumps and fuel tubes.
    Quite a few of the C's and E's were converted over to the L10. I can definitely recommend that option, I worked on plenty of those and most customers were happy with them
  11. Birken Vogt
    Birken Vogt Charter Member
    Nov 30, 2003
    3,061
    Grass Valley, Ca
    I have no experience with them as tractor engines but as truck engines I have about a zillion miles on the old 8.3s. They were extremely reliable. Once DPF came along not so great like everything else. But the old ones with CAPS pumps or whatever came before seemed to be as good as a 5.9, just a reliable running engine.
  12. illinoisboy
    Sep 17, 2009
    146
    contractor
    Greenup
    The 573 and the v800 are different engines. My c has a 573. I like the l10 option but need the bell housing and flywheel to match the TC I have. Searching the internet is never ending. Lol
  13. Jock
    Oct 24, 2012
    55
  14. RZucker
    Jul 7, 2013
    4,102
    Mechanic/welder
    Wherever I end up
    Actually... If you read the thread nobody suggested to the OP to install a Detroit engine. My first post was a comparison about the possibility of differing governors. Also the OP has a 573 engine... my only experience with TD 20's were the E series and they had the V800, Miserable POS in my opinion and a Detroit would be a Major improvement. I have replaced 903 Cummins engine several times with 8V-92's and the result was a smoother running machine with cheaper parts availability and actually better fuel economy. So just save the Detroit hate.
  15. td25c
    td25c Senior Member
    Feb 15, 2009
    5,251
    indiana
    Can you not swap the front cover & gear train so you could use the original V pump on the good 573 engine ?
    Build up one good 573 out of the two engines .
  16. oldirt
    Apr 22, 2009
    504
    iowa
    to rzucker.. go back and read post #6.
  17. td25c
    td25c Senior Member
    Feb 15, 2009
    5,251
    indiana
    Some people don't realize what there missing out on RZ .:)
    6 V 92 was another option I thought of in illinoisboy's other TD 20 C engine thread .
    Engines & parts readily available at a reasonable cost & more than enough power .https://www.heavyequipmentforums.com/threads/td20c-motor-swap-to-466.61296/#post-651410
    What few TD20 C 's I've been around with the V 8 engine noticed there aint allot of extra room between the hard nose & bell housing .
    That machine was built for a V8 . Would an in line 6 even fit ?
  18. RZucker
    Jul 7, 2013
    4,102
    Mechanic/welder
    Wherever I end up
    Go back and reread it yourself. That poster was talking about the V-800 did not mention that the OP should go Detroit.
  19. RZucker
    Jul 7, 2013
    4,102
    Mechanic/welder
    Wherever I end up
    I have never dealt with a C model. The E's had the V-800 that was a miserable piece of junk that shook the machine apart. I have seen an IH 4366 repowered with an 8V-92 that the owner said was the best thing since sliced bread. Again, it was the best solution to the original engine package space. Another 8V-92 repower candidate was the 4994 Case tractor with the POS Scania V-8, they could shake themselves to bits. Hmm, the 8V-92 just purred.
  20. td25c
    td25c Senior Member
    Feb 15, 2009
    5,251
    indiana
    Well that does it RZ ! You just sold me on a Detroit engine Bro !;):D
    I've worked around a few TD 20 C's with the V8 and just remember seemed like there was not allot of extra room under the hood .
    Take a look at this one & see what ya think ?
    http://tractors.wikia.com/wiki/International_TD-20C
