TomMD
Hi All,
New to the forum and hoping someone may have some insight. I have a 2006 TB138FR. The AIS has recently been triggered and won't raise the boom or rotate to the left. I'm aware thats what should happen when a sensor fails or something along those lines. I'm not sure where/how to start diagnosis on what component has failed. I also have a 2015 TB153FR that had a similar issue. The fuse box in the cab had a bad fuse for the AIS and after I replaced that everything has been fine since. The 138FR does not have a dedicated fuse in the cab, and all appear to be in good working order. I'm not sure where to start now with the 138 since I can't find a fuse or relay. I know there are two sensors located at the base of the boom, I'm not sure if I should just replace them and see if that works. I believe there is a third somewhere else lower on the side to side swivel, but I haven't located it yet.
If anyone has some suggestions on where to start, I'd greatly appreciate it! I'd take it to the local dealer but have had some pretty terrible experiences in the past and really want to get the machine back up and running.
Thanks again!
Thanks again!
