Takeuchi TL150 Stalling
Discussion in 'Skid Steers' started by wittenterprises, Apr 17, 2014.
  1. wittenterprises
    wittenterprises New Member
    Apr 17, 2014
    3
    Spotsylvania, VA
    Machine stalls out randomly. It can be immediately after you start it up and the engine is still cold or it can be after running 20 minutes. Sometimes it cranks right back up and sometimes you have to crank it over a lot to get it to fire back up. It has a new oil change and the level is good. It has a new fuel filter. the water separator is clean. I changed the 2 hydraulic filters on the machine. The coolant level is good.
    Any suggestions ?
  2. cartzblown94z
    cartzblown94z Well-Known Member
    Nov 10, 2009
    124
    Monroe Center, IL
    Mine did that when I got it on cold starts but it was because I wasn't turning the key backwards for the grid heater to warm up. Now it's fine. Never had issues while running after a few min though
  3. Swannny
    Swannny Senior Member
    Jan 10, 2012
    271
    USA
    Sensor going bad? Are the air filters clean? Fuel lines sucking air somewhere?
  4. stumpjumper83
    stumpjumper83 Senior Member
    Jan 13, 2007
    1,961
    Movin dirt
    Port Allegany, pa
    are the dash lights coming on?
  5. kevinc1650
    kevinc1650 Member
    Feb 18, 2012
    24
    Jemison, AL
    Are any lights coming on? Takeuchi has electric fuel pumps mounted on the door. Check and see if it is working. Check the fuel lines at the door. See if the line has a bent in it causing it not to get alot of fuel though it. Check the filter in the water/sep. If no lights are coming on it will be a fuel problem more then likely.
  6. wittenterprises
    Apr 17, 2014
    3
    Spotsylvania, VA
    Air filter is clean, fuel lines all appear to be ok
  7. wittenterprises
    Apr 17, 2014
    3
    Spotsylvania, VA
    Kevinc1650
    There are no lights coming on. The fuel separator is clean and drained.
    Yesterday morning I go, it cranks up and shuts down immediately, just as if I turned the key off. It cranked back after a lot of cranking, It stayed running for several hours until I turned it off. The throttle responds well, no hesitations.
    This morning the exact same thing.
    There are no lights coming on while running or after it shuts down.
    All the fuel lines appear to be good.
    thank you for taking time to help
  8. heymccall
    heymccall Senior Member
    Feb 20, 2007
    3,349
    White Oak, Pa
    On every TL150 here, I have had to resolder the contacts in every relay above the operator's toes. Normal people may simply replace the bad one, but which one?
    Systematically disassemble on at a time, and examine their internals for cold solder joints.
  9. heymccall
    Feb 20, 2007
    3,349
    White Oak, Pa
    I have also had many, many, many issues with debris in the fuel tank, because "it takes too long" to fuel the machine with the filler neck strainer intact. The fuel tank is a nearly "bottom suck" setup. The fuel outlet "90" has a tendency to not pass rocks or straw.
  10. cartzblown94z
    Nov 10, 2009
    124
    Monroe Center, IL
    Are you using the grid heater before starting?
  11. Chief Jim
    Chief Jim Well-Known Member
    Aug 25, 2011
    60
    worm farmer / American
    Southern Ohio
    Locate the fuel line on the filter that comes from the tank. When your machine dies, take that line off the filter and blow into until you hear bubbles in the tank, put the line back on , turn the ignition on and wait a moment for the fuel pump to recharge the lines. Run it. Mine did the same thing. You may have a piece o crap in the tank that plugs the fuel line. Blowing air back through it may clear it temporarily. Take the fuel cap off and DO NOT pressurize that tank. Good luck.
  12. curtdog21
    curtdog21 New Member
    May 6, 2015
    3
    alabama
    mine was doing the same thing. it would blow the fuse for the fuel pump. the wires in the back door got pinched. fixed that and it runs great. i have a problem w 2 lights staying on. the battery light blinks and the one that looks like an axle and an oil drop. i was wondering if anyone could explain this to me.
  13. tool_king
    tool_king Senior Member
    Mar 29, 2010
    1,940
    road mechanic owner
    new jersey
    curtdog21
    the light may be the hydraulic filter light .What is your email address?I can send you operation ,partsand service manuals in pdf .
  14. curtdog21
    May 6, 2015
    3
    alabama
  15. Chief Jim
    Aug 25, 2011
    60
    Southern Ohio
    Two light fault on TL150
    Whack the relay box by your right foot with a hammer . If the problem goes away it may be a relay sticking. Clean all those connections. If problem keeps occurring, you may need a relay. $60 give or take a few bucks. I could not identify a non OEM replacement for the Knight Beam Company Ltd relays. There are two relays the same, you can try a simple swap to see it that helps...
    Good luck. Chief Jim
  16. curtdog21
    May 6, 2015
    3
    alabama
    Any help is much appreciated!!!
