jkb5036
Hello all. I have a wiring problem with my TL140. I did an annual service on it, pulled it out of my garage, and it has sat for about a month. Haven't had time to run it! So tonight I finally got a chance to run it. I turned the ignition on and NOTHING. No lights, no accessories, no gauges, nada. I automatically thought it was a dead battery. I proceeded to charge the battery but it wasn't taking much of a charge. Tried the key again, and still nothing. Tried jumping another battery to it, nothing. Went to the fuse panel in cab and it looks like there is no power to that fuse panel. So I started back at the battery and started tracing. I pulled all 3 fuses above the battery and checked voltage there. All fuses were good and I'm getting 12v at all three. I didn't know where to go from there because I do not have a wiring diagram. I did notice under the right side backup light (inside like where the backup siren is) there is a solenoid in very rough shape. It almost looks like it's burnt up. Does anyone know what this solenoid does? Would that keep me from getting power to the ignition? Or does this sound like it's in my key switch? I checked resistance from positive battery terminal to ground and it's an open circuit, so there is no ground. I'm lost and have no clue what else to look at. Any advice is greatly appreciated. Thanks!
