miked_9606
I have a 06 tl130. Original issue was battery flashing causing the engine to shut down. Limped it back to shop and parked it. Ordered alternator, put in, took machine out to test same issue. Limped back in shop. Turned off. Immediately after turning off I cannot get it to turn over just clicks. Clicking comes from solenoid in back right below the 3 big inline fuses by battery. Checked ground, checked battery, pulled starter (dead on bench). Replaced with new starter. Same issue. Turn the key just clicks. Every once in a while to no rhym or reason you turn the key and the starter will turn over. That is very rare. If toggle key 30 times it may happen once. Any ideas?? Need help
