Takeuchi TL130, Hydraulic oil change. Bleeding system?
Discussion in 'Compact Track/Multi Terrain Loaders' started by azvacs, Sep 20, 2021.
  1. Nige
    Nige Senior Member
    19,033
    I'd be interested to know why.
    The oil recommended by the OEM is a 10W/30 engine oil, probably recommended so that it would encourage people to use the same oil in the engine and the hydraulic system. There are far better oils available for hydraulic systems than engine oils.
  2. azvacs
    azvacs Well-Known Member
    Feb 12, 2021
    62
    Construction Co. Owner/Mechanic
    AZ
    I’d be interested to know why also. And you suggest 10W TO4? It may mix with whatever is still in the lines and pump. Others on this thread have said that they wouldn’t use 10W oil in the hydraulic system…
  3. azvacs
    Feb 12, 2021
    62
    AZ
    Are you saying that 10W TO4 is straight 10W?
  4. Nige
    Nige Senior Member
    19,033
    If HMC runs 10W in all his Tak hydraulic systems that would be good enough for me. We ran 10W in all our hydraulic systems on other brands.
    TO-4 or HYDO (hydraulic oil), either will work just as well.
  5. skata
    skata Senior Member
    May 10, 2007
    1,265
    midwest
    10w30 is a 30 weight when hot. What is the weight of the t04 when hot?
  6. skata
    skata Senior Member
    May 10, 2007
    1,265
    midwest
    I don't know? Sounds like it.
  7. Nige
    Nige Senior Member
    19,033
    The question would be why anyone would want a oil viscosity as high as 30 when the oil is hot.?
    Most manufacturers specification for hydraulic oil is for a straight viscosity oil somewhere around SAE10W.
  8. skata
    skata Senior Member
    May 10, 2007
    1,265
    midwest
    10w30 is what Takeuchi has been using for a long time. I'm running 10w-40 now.
