Takeuchi TL130, Hydraulic oil change. Bleeding system?
Discussion in 'Compact Track/Multi Terrain Loaders' started by azvacs, Sep 20, 2021.
  1. azvacs
    azvacs Well-Known Member
    Feb 12, 2021
    59
    Construction Co. Owner/Mechanic
    AZ
    Going to drain the hydraulic tank and change out a couple of hoses and filters. What is the process for bleeding air out?
  2. azvacs
    Feb 12, 2021
    59
    AZ
    And how many filters are there?
  3. heymccall
    heymccall Senior Member
    Feb 20, 2007
    3,144
    White Oak, Pa
    Spin on & pilot
    No special procedure that I'm aware of.
  4. azvacs
    Feb 12, 2021
    59
    AZ
  5. PeterG
    PeterG Well-Known Member
    Apr 15, 2015
    175
    Landscape Construction, General Contractor
    Seattle WA, United States
    For all Takeuchi machines, Use 41 mm wrench ( I have a 41 mm striking wrench, a long huge 41mm open wrench and a 41 mm socket) to add more hydraulic fluid. Let idle for ten min to bleed, then extend all hydraulic cylinders.
  6. heymccall
    Feb 20, 2007
    3,144
    White Oak, Pa
    I uses a 1-5/8" wrench in lieu of having metric.
  7. azvacs
    Feb 12, 2021
    59
    AZ
    I bent a 24" breaker bar with a iron pipe over it, trying to get the 41mm fill cap off. Went and got a heavy duty 1/2" impact gun. Hopefully that will work.
  8. azvacs
    Feb 12, 2021
    59
    AZ
    Gave up on the top cap.! No way its coming off. I've tried a 41mm 6 point socket and 4' breaker bar, 1200lb impact gun, heat, etc.... Won't even budge. I guess I'll just fill it through the breather. IT'S NOT COMING OFF!
  9. heymccall
    Feb 20, 2007
    3,144
    White Oak, Pa
    C'mon...I've been there.
    1-5/8" box wrench with another on the open side or 3/4" ratchet with 4' cheater. It's the jolt that breaks them free.
  10. skata
    skata Senior Member
    May 10, 2007
    1,230
    midwest
    Did someone prank you? It shouldn't be that hard.
  11. azvacs
    Feb 12, 2021
    59
    AZ
    I know! It should not. Gonna try again tomorrow.
  12. azvacs
    Feb 12, 2021
    59
    AZ
    FD19CA6E-7CE3-4D95-81CB-E11F51A41D87.jpeg F1BCC7ED-2CC5-494F-ABF4-A8A05D695549.jpeg Well that didn’t go well. Does this look like someone welded this fill cap on?
  13. azvacs
    Feb 12, 2021
    59
    AZ
    You tell me. What do you think? I’m stumped
  14. azvacs
    Feb 12, 2021
    59
    AZ
    Take a look. What do you think is going on here? Stumped!
  15. skata
    skata Senior Member
    May 10, 2007
    1,230
    midwest
    Weird. Do you see any gap between the bolt and round tank part?
  16. azvacs
    Feb 12, 2021
    59
    AZ
  17. azvacs
    Feb 12, 2021
    59
    AZ
    I guess i could try a impact chisel, but then the top of the cap nut would be FUBAR! I think I’m spending to much effort on it and should just take the breather off to fill it… HAHA
  18. azvacs
    Feb 12, 2021
    59
    AZ
    You’re shaming me with how clean that machine of yours is. WOW
  19. skata
    skata Senior Member
    May 10, 2007
    1,230
    midwest
    Assuming the factory didn't install a welded plug, I'd try heating the round boss that the bolt threads into, and then hit it with an impact or breaker bar.
  20. skata
    skata Senior Member
    May 10, 2007
    1,230
    midwest
    Lol. No it's just pictures I found online to give you a comparison.
