There is a Tak dealer in Georgia that I have followed on FB for a while:
519 Bonnie Valentine Way
Pendergrass, Georgia 30567
(706) 693-3600
Just to warn you in advance, Takeuchi support of older gear is pretty bad, a lot of the OEM's don't support them past ten years, sometimes less. For example, the track motor in my tb25 is shot, and I can't get gears for it. On the bright side, there are replacments for pretty much anything else if you look around a bit. (My fuel pump for example is from Kubota, same PSI........)
Also, would anyone know where I can find these Takeuchi Parts at a decent price...not sure on the solenoid yet, but do need the other two. Used is fine as long as they work.
1998 Takeuchi TL26 (TL26-2) Serial# 2620198 or 2620798 (kind of hard to read)
I need the following parts:
Engine Stop Solenoid: Part # I8-94453-3411
Left Pilot Valve: # 1901723300
Left Joystick Boot: # 1901710941
