Takeuchi TL10, how do I adjust idle speed that’s too high and where is it located?
Yakima
Oregon
I got this machine a year ago. The idle speed is way too high!
it’s at 2500rpm.
how do I adjust it, and where is the adjuster located?
thepumpguysc
Sunny South Carolina
Master Inj.Pump rebuilder
It depends on if u have a common rail system or a mechanical inj pump.
If it’s a mechanical inj pump..
Make sure the throttle LEVER is touching the stop screw.. if not, you’ll have to adjust the LINKAGE..
If it is touching the stop screw, all u have to do is loosen the lock nut and turn the SCREW OUT.
Good luck
ozarkag
ozarks
If it is the common rail Kubota could possibly be stuck in a regen cycle. Any active codes? Throttle work otherwise? Full power?
Yakima
Oregon
Thank you, I’ll try that
it does have a code. I need follow up on that still.
It has to do with the oil pressure.
I installed an oil pressure gauge to be sure of the oil pressure.
it has a steady 45 psi while running. Now I can be sure of the engines oil lifeline.
i never cared for idiot lights.
