Cory Baxter
Down2earth where did you find what the flash codes mean. My Tl240 is doing the no cranks have power but my light is flashing 6 times
Well on a tl140 the best access is from below, remove the belly plate. I've had my wiring connector at the solenoid get corroded and cause issues. I just direct wired it.Can someone please tell me where the fuel solenoid would be on takeuchi tl240 cant get the engine to start thanks
How did you direct wire it? Do you mean that you eliminated the connector? I have a TL130 that won’t pull in the stop solenoid. But i also think i have a bad alternator.Well on a tl140 the best access is from below, remove the belly plate. I've had my wiring connector at the solenoid get corroded and cause issues. I just direct wired it.
Yeah I just cut the connector ends off and connected the wires together.How did you direct wire it? Do you mean that you eliminated the connector? I have a TL130 that won’t pull in the stop solenoid. But i also think i have a bad alternator.
Yes, i have 12 volts on the hold and nothing on the pull wire with key on or cranking. It should be momentarily, to pull in, but i have nothing.Yeah I just cut the connector ends off and connected the wires together.
Not sure how an alternator would affect a fuel solenoid.
You check for voltage at the fuel solenoid?
Not sure what pull and hold mean, but your solenoid should be energized when the key is turned, and stay on, until you turn key off.Yes, i have 12 volts on the hold and nothing on the pull wire with key on or cranking. It should be momentarily, to pull in, but i have nothing.
