Hi,
Could someone please help me out here, I have a 2012 Takeuchi TB138FR Cabin zero tail swing excavator with 74hrs on it. It’s Almost brand New.
Just wanted to know if it’s normal that when you’re digging through firm soil (not clay) using the 400mm digging bucket or scraping back for driveways using the mud bucket that the engine RPM drops significantly? It doesn’t Stall but you do hear it drop significantly.
I’m not sure if this is normal or if there is an issue with the engine or hydraulic system?
Can the hydraulic system or pressure be adjusted? As in how much is used for digging or how much is used for crawling??
Is there some type of valve (s) that can be adjusted?
I’m trying to determine if it’s a problem or if it’s how the machine operates normally under load.
Also its just had the 50hr service, new filters, new engine oil etc.
Takeuchi mechanics here don’t seem to want to help me out as the warranty has run out.
Any help would be appreciated.
Thanks
Steve.
Thanks
Steve.
