takeuchi 230 series 2 skid steer
Discussion in 'Compact Track/Multi Terrain Loaders' started by turbotoys, Sep 16, 2021.
  1. turbotoys
    turbotoys Member
    Feb 4, 2012
    13
    Tampa
    Hello
    So i noticed a lack of power and eventually machine would stall, now it seems like it willl start every once in a while but when I increase the load it stalls. I inspected fuel filter and it appeared to have a little water in it, I then drained the water seperator on back door. I also pumped about 9 gallons of fuel out of the tank. Then replaced filter, and a couple of gallons of diesel. It would start up again but stall stall out after a short time. I did notice the water seperator did not fill all the way back up and I am wondering if the self priming pump is starting to fail. Is there a set pressure I should get at the discharge of that pump? The water seperator is see through and it seems like it takes a long time for that to fill up.
    Thanks for reading. Let me know your thoughts/ ways to proceed.
    Jim
  2. Vetech63
    Vetech63 Senior Member
    Aug 10, 2016
    4,033
    Oklahoma
    Check your suction line for a restriction before you do anything else. Also check for suction leaks on the suction side of the supply pump.
    mg2361 likes this.
  3. heymccall
    heymccall Senior Member
    Feb 20, 2007
    3,341
    White Oak, Pa
    Vetech63 likes this.
