Takeuchi 135, first start of the day
Discussion in 'Compact Excavators' started by StPat, May 22, 2020 at 6:59 PM.
  1. StPat
    StPat Member
    Oct 13, 2007
    15
    AK/NM
    I have a Takeuchi 135, 2007, about 3500 hrs. At the start of every days operations the machine will not start unless I put the battery charger on it, set to 140 amps starting, machine then will start right up and run fine for the rest of the day, doesn't make any difference if the machine has been in the shop overnight or outside.I put a new battery in it, no change, glow plugs seem ok, so I'm thinking starter rebuild, anyone have more suggestions before I tear into the starting system?? I'm in Alaska but the machine is kept inside during the winter in a heated shop, so I don't think temperature is the problem.
    Thanks in advance, Patrick
  2. heymccall
    heymccall Senior Member
    Feb 20, 2007
    1,922
    Monroeville, Pa
    Will not rotate the engine?
    Rotates engine, but no smoke from exhaust?
    Rotates engine, white smoke from exhaust?
    Clarify, please.
    Are you using proper sequence to start?
    1/8 throttle.
    Rotate ignition switch CCW until glow lamp goes out.
    Rotate ignition to crank.
    Start engine.
  3. elcheapo
    elcheapo Active Member
    Aug 11, 2013
    27
    Florida
    Have you tried disconnecting the battery overnight ? Just in case something is draining the battery during the night.
  4. StPat
    StPat Member
    Oct 13, 2007
    15
    AK/NM
    Followed proper start sequence, has new battery, engine turns over fine no unusual smoke or vapors, seems like the engine is maybe turning over a little slow but starts and runs fine after initial high amperage shot. Thinking maybe armature has buildup on it not allowing starter to spin up on first start of the day. I will try to get a amperage reading at first start and compare it to subsequent startups. Thanks for reply, the mystery continues! Patrick
  5. Canuck Digger
    Canuck Digger Well-Known Member
    Dec 24, 2012
    207
    Business Owner, Equipment Operator, Fishing Guide
    Mission, BC, Canada
    I'm not a mechanic by any means but, things that have helped me in the past for "hard" starting:
    plug the machine in overnight
    run thinner oil
    There are obviously things that are temperature related. Shouldn't be an issue when the temp perks up a little.
  6. MarshallPowerGen
    MarshallPowerGen Well-Known Member
    Nov 27, 2017
    156
    Diesel & Generator Mechanic
    Coeur d'Alene, Idaho
    Check cables and clean connections, then see what you get for voltage drop or amperage while cranking. Also monitor your battery voltage that your alternator is charging properly and for any parasitic drain overnight.
  7. BBoudreaux
    BBoudreaux New Member
    Dec 30, 2013
    4
    South Louisiana
    My machine acted very similar, I found one of the hoses at the engine mounted fuel filter damp looking, I cut about an inch off and reconnected, helped a lot, must have been getting some air in the system after sitting for a while.
