Take me to school.......
Discussion in 'Dozers' started by Vetech63, Jun 12, 2018.
  1. Vetech63
    Vetech63 Senior Member
    Aug 10, 2016
    420
    Oklahoma
    A customer has contacted me about brakes dragging on a D6T S#WHF00364. I know NOTHING about these. From the sounds of what they are saying it may be leakage or a flow problem. Works great for a hour or 2 in the morning, then they start dragging the machine down. SO...…..Ive got my thinking cap on and ready to learn.
    No active codes that Im aware of. I wont be seeing this machine for a few days so I have a bit of time to study.
  2. DMiller
    DMiller Senior Member
    Feb 22, 2010
    3,372
    Retired
    Got to looking at specs on these, have they gotten away from Hydrostat and gone back to Power shift for real??
  3. kshansen
    kshansen Senior Member
    Mar 11, 2012
    5,200
    Central New York, USA
    Any chance you transposed some letters in that S/N? WHF does not seem to work but WFH does.
    MHDim likes this.
  4. MHDim
    MHDim Member
    May 12, 2018
    21
    Service Engineer
    Cluj-Napoca, Romania, Europe
    I would operate the machine until the problem appears, and then I would measure the pressures at the brake control valve (located under the operator's seat), AND at the transmission main relief valve (pressure tap should be available outside, at the upper rear of the transmission case).
    LATER EDIT - the brake control valve is under the seat, but in order to check pressures, normally the seat shouldn't need to come off. On D6R, you have access to the brake pressure taps from the rear of the machine... if you have a long arm :) - I think it should be roughly the same on the D6T.
    Brakes are spring-applied and pressure-released; the brake control valve and the transmission are supplied with oil from the same section of the power train oil pump.
    If there's insufficient pressure only at the brake valve, I would start by taking it off, inspecting and thoroughly cleaning it. If all looks OK and/or the problem still persists, and if you say no error codes are present (meaning electronic control system is OK), then I'm afraid it looks like the final drives (together with the brakes) will need to come off, in order to check for worn brake seals...
    If there's insufficient pressure at the brake valve AND at the transmission main relief valve, I'm not 100% sure but I think I would check the main relief valve itself (inside the transmission control valve, under the rectangular cover at the rear of the case) and/or the respective section of the power train pump. I repeat - not 100% sure, but still easier to check than separating both tracks and removing both final drives (including removing the steering diff. motor, which is a pain in the a*$...)...
    Also, if the machine has a ripper, it's worth suspending it on the blade & ripper, and checking if both brakes are dragging, or only one of them.
    Right now I don't have time to look up / attach procedures & instructions, hope I'll be able to do so later tonight, or tomorrow.
    BTW, there seems to be a typo with your s/n - I'm guessing it should be WFH00364 (rather than WHF00364...) :)
    Vetech63 likes this.
  5. Vetech63
    Aug 10, 2016
    420
    Oklahoma
    Yes, you are correct. My bad
  6. Vetech63
    Aug 10, 2016
    420
    Oklahoma
    This is power shift for sure.
    DMiller likes this.
  7. Vetech63
    Aug 10, 2016
    420
    Oklahoma
  8. Vetech63
    Aug 10, 2016
    420
    Oklahoma
    I should have more coffee before I start clicking stuff on here.o_O You have explained it pretty well to me. I don't believe the pressure taps are marked so Im not sure which is which. What kind of brake pressure should I be seeing at operating temp? Is there not a sensor monitored by the computers to measure brake pressure? I would think if its below spec something electrically would be popping up on the display.
