T590 no crank
Tintom1995
Ohio
Hello, I have a 2014 t590 replaced the drive belt, reinstalled battery and no crank. I replaced the relays and checked all the fuses, checked out good. Getting 12v at the starter. However I am not getting anything at the feed wire when key is turned into the crank position. I’m not getting any codes unless I hold the key to crank for to long then I get the m2302 starter relay off. The machine started before I replaced the belt and I double checked everything I took apart to make sure I didn’t leave anything disconnected.
fortworth-cowboy
Near Fort Worth, TX
Did you put the 3 Wire Connector back together? It is located by the battery, which you had probably out because of the drive belt.
Tintom1995
Ohio
