Austin Hammett
Hey y’all, need help with a 2008 Bobcat T320 cab machine
Codes it is throwing are D7501, H3928, D3907
Machine does not want to travel, sometimes it does, but only several feet, when it does travel the ISO/H switch is illuminated in the appropriate pattern, when it wont travel the switch blinks intermittently.
When pressing the operate button, the park light turns off, then right back on.
The belly bar indicator on the panel works as it should (means switch is working?)
Recently is has traveled more than a few feet, and when it does, all sorts of silly stuff happen. The park brake will turn on suddenly sometimes, or it will be stopped, and all of a sudden travel forward.
Low hour machine in good shape, no obvious tears or frays in wires under cab.
It HAS been sitting for several years due to this issue.
Before pointing fingers at a bad joystick, or two, have any of you had the same issue or even similar with other makes? If so, what was the end result?
Thanks in advance.
Thanks in advance.
