T300 Bobcat tilt /lift light flashing
Bubba
Lagrange Georgia
Locomotive Engineer, Property Management, Clearing
I got a Bobcat T300 serial # 532012017; the Tilt/ Lift light started flashing which is the 3rd light from left on left side of instrument panel. I raised the seat bar thinking it may have lost connection which triggered the fault. Lowered seat bar aggressively thinking it may was not making contact with safety switch. It did not correct the problem. This all happen about an hour of running after we spent all day replacing the AC compressor. Can anybody suggest what may be my problem. Thanks
Bubba
Lagrange Georgia
Well we got it figured out. Replaced the coil on control valve. It has 3 coils, the one in the middle. Two on each side deals with aux. the lift / Tilt is in the middle. Code was 17-06 , unplug it then start machine if you get 17-07 it’s a bad coil. Cost for part $65.00.
