bobcatmechanic
When compared to other loaders of similar size, the T110 provides an excellent horsepower-to-weight ratio that provides pushing and digging forces to quickly complete work. The durable, all-steel undercarriage — similar to what is used on larger Bobcat track loaders — withstands the toughest digging conditions, while the flotation of the rubber tracks prevent damage to existing turf and keep the machine working in wet and muddy conditions. The T110 can travel through narrow openings or grade on narrow lot lines without treading on a neighbor’s property. With 26 available attachments, the T110 compact track loader is a versatile and productive machine.
T110
Kopykat
Quick Specs
Engine
Emissions Tier (EPA):Interim Tier 4
Engine Fueliesel
Horsepower:41.8 HP
Turbocharged Engine:false
Performance
Rated Operating Capacity (SAE):1100 lbs
Operating Capacity (50% of Tip):1595 lbs
Tipping Load:3190 lbs
Operating Weight:5202 lbs
Travel Speed - Low:5.2 mph
Ground Presssure (Rubber):4.56 psi
Capacities
Fuel Tank:11.9 gal
Cooling System:11.6 qt
Hydraulic System
Pump Capacity:12.5 GPM
Dimension
Length:89.7 in
Length with Standard Bucket:117 in
Width:47.2 in
Width (with bucket):50 in
Height:74.1 in
Height with Operator Cab:74.1 in
Height to Bucket Hinge Pin:103.7 in
Reach @ Maximum Height:22.8 in
Length of track on ground:51.1 in
Track Width:9.8 in
Controls
Attachment Hookup:2 Lever
Features
Joystick Control:n/a
Air Conditioning:n/a
Backup Alarm:std
BICS System (Interlock):std
Cab Enclosurept
Enclosed Operator Cab (ROPS/FOPS)pt
ROPS/FOPS Approved:yes
Cab Heaterpt
Operating Lights:std
Suspension Seat:std
Two Speed Travel:n/a
Deluxe Instrumentation:n/a
Engine Shutdown:std
Hydraulic Bucket Positioningpt
High Flow Option:n/a
Bob-Tach Attachment System:std
Power Bob-Tach:n/a
Horn:std
T110
Kopykat
Quick Specs
Engine
Engine Fueliesel
Horsepower:41.8 HP
Performance
Capacities
Fuel Tank:11.9 gal
Hydraulic System
Dimension
Length:89.7 in
Width:47.2 in
Height:74.1 in
Track Width:9.8 in
Controls
Features
Backup Alarm:std
Cab Enclosurept
Cab Heaterpt
Suspension Seat:std
Engine Shutdown:std
Power Bob-Tach:n/a
Horn:std
