geeboy67
our t-190 just started to shut down after using it 2-3 hours ,it will start right back up, but shut down again . if you let it sit for an hour it will run for a good hour . let it sit over night and it'll run 2-3 hours again then same senario. seems like a temperature problem but temp. is fine ,also oil level is fine . could there be a temp sensor going bad that is doing this? if so, where would it be located at ? any help would be appreciated .
