Swimming pool Removals and Demolitions
Discussion in 'Demolition' started by David Attard, Jan 7, 2021.
  1. David Attard
    David Attard New Member
    Jan 7, 2021
    1
    Swimming Pool Removals and Demolition Contractors
    Riverstone NSW Australia
    Hi guys! Here you can post, share, discuss different types of swimming pool removals and demolitions tips, costs, things to remember, and many more.
  2. aighead
    aighead Senior Member
    Apr 25, 2019
    1,562
    Dayton, OH
    I'm pretty sure this isn't really what you mean but...
  3. Rosensteel1488
    Rosensteel1488 New Member
    Jan 2, 2021
    3
    Connellsville, PA
    I haven't demo'ed any but I've installed more above and inground pools than I can count. I think the most important part would be making sure you bust the bottom up so they don't hold water. Depending on what part of the country you're from, you'll be dealing with different types of materials. The most common ones around here are a vermiculite (sp?) bottom with steel panel walls. The walls are bolted together like a giant erector set with braces that get covered in concrete. Getting those out might be tricky, depending on what kind of equipment you have. I've seen people make their own pools with block walls and concrete floors, tearing them down pretty much explains itself. The gunnite and concrete pools dont necessarily hold up that well due to the freezing and thawing that happens around here. You have to paint the concrete pools every few years and seal up cracks, a lot of people get tired of dealing with this and modify them to accept a typical liner.
    I'm not sure if any of this gives you the answers you want or not. I figured I'd at least be able to give you an idea on what you're up against. It's probably all general information that you already know, but I just wanted to feel important lol.
    Tags likes this.
  4. 805DirtDog
    805DirtDog Member
    Jul 20, 2019
    17
    Forman
    Central Coast, CA
    I’ve demoed a few out here. All gunnite with a **** ton of rebar. We work our way down from the coping with a hoe mounted breaker. Process as you go (remove most of the steel) and as the bottom of the pool fills up with rubble it’s easy to get a couple clean loads out before dealing with the mud under the bottom. A lot easier to just break up the top two feet and fill in the rest
  5. RickW4
    RickW4 Member
    Apr 6, 2021
    14
    Phoenix, Arizona, USA
    How long does it usually take to clean out all the mud and rubbles from the bottom?
