First off thank you,Voodoomojo,and sorry about the picture confusion,that was just to piont out no.46 which was not in the previous pic.hence the different numbers.
but I do appreciate your experience and help.I will check those areas for the valve in question.as for the next question from another member Hardline,The service I did was in response to the original problem,the speed control cable snapped and the compressor would only idle,so after repairing it,i checked the oil and found it down 2 1/2 gallons
so we added AW46 hydraulic oil.thats when the next problem kicked in the blowback,but i question it because if it was that low,yet still ran good,why then after ejecting the oil does it still not run right,perhaps the problem as voodoomojo sugested with the check valve was there all along and by adding oil it did what I suspect now it did a while back,because now im told,a while back the oil did blow all over and I was never told,therefore never bothered to check or add oil to the system,Now im thinking what ever caused the cable to snap could be a new problem,it snapped where it attaches internally at the intake control valve which as I read on controls the air suction at the compressor end.I guess i should check and clean all the lines and valves and see where I go from there. Thanks again for all thge help so far.
