I have a 1996 Sullair 185 DPQ compressor that is having issues. We have been using it to sandblast with and it has been blowing oil into the moisture separator on the blast pot. Also it is blowing oil out of what i assume is some sort of bypasses, one is right above the compressor head on the left side and another near the back of the control panel. It has been cold so i was thinking maybe something is freezing but we have kept the hoods closed and it seems that everything is warn inside the machine. Also, we went to top off the compressor oil shortly after shutting down and there was a bit of pressure behind the oil filler plug. It will slowly overflow when removing the cap. Any ideas??
