Hi to all. I have been reading the forum for a few weeks and lots of good information from lots of informative members. I have recently pu8rchased a Komatsu D37E-5. This past weekend was the first time I had the opportunity to use it. I don’t have anything to compare it too, but it seemed to do well. At first it would hardly turn left, the left turning brake just wouldn’t grab like it should. I read the instruction manual and adjusted both brakes according to the procedure in the book, tighten to about 28ft/lbs and then loosen the adjustment bolt by 2.5 turns. After doing so, the right brake seemed to operate properly but the left steering clutch and brake did not. At idle, when moving the joystick to the left the engine would noticeably bog down. It seemed as if the steering clutch was not disengaging before the brake would apply. I ended up adjusting the left by trial and error, I kept loosening the left brake bolt to the point where it just would not lock up the left track and then tightened it back up to where it would engage and the track would stop. I ran it for about 15 hours over the long weekend and nothing changed from that point. It operated just the same after the adjustment as it did after 15 hours of work.
Not knowing much about the dozer I figure I would ask the question about how it “should” operate. My understanding is the as the joystick is slowly moved one direction or the other, the steering clutch should disengage and depending and the circumstances, the dozer should veer in that direction without the track locking up. When the joystick is moved all the way one direction or the other, the steering clutch should release and the steering brake should lock up. It seems to work properly when turning right. But turning to the left I need to move the joystick all the way over.
My question ends up being is there an adjustment for the steering clutch as well. I have been unable to find a procedure on this in the book. They guy I purchased the dozer from said there was no adjustment.
Thank you in advance for setting me straight.
:Banghead
:Banghead
