Starting system issues
Discussion in 'Forestry Equipment' started by daveyclimber, Oct 18, 2018.
  1. daveyclimber
    daveyclimber Active Member
    Aug 3, 2017
    29
    Cottonwood, CA
    Been having Issues with a Prentice 2670 . If the machine sits for more than 1 day it will not start without a boost. I have noticed while attempting to diagnose the problem that I have 10.75 volts at the negative terminal, 1.68 volts at the positive terminal and about 12.48 across both terminals. Why does my negative terminal have voltage? What is the best way to diagnose and fix this issue?
  2. kshansen
    kshansen Senior Member
    Mar 11, 2012
    8,022
    Central New York, USA
    My first question would be where at you connecting the other end of the tester while checking the terminals?
    Not fully picturing how you are doing these tests but one simple test might be to remove one wire from the battery and see if after it sets for a few days it starts when reconnected.
    I'm knd of thinking if you remove one cable from the battery with engine shut off you will see s bit of an arc due to something drawing power even with key off.
    Has anything been done to this machine lately?
  3. daveyclimber
    Aug 3, 2017
    29
    Cottonwood, CA
    I pulled the negative lead off battery. Neg lead from meter to neg terminal, positive lead from meter to neg lead. 10.75V.
    Meter + to Bat +, meter - to chassis 1.68V
    Meter + to Bat +, meter - to Bat - 12.48V
    New stereo but had this issue before then. I am the 2nd owner and it has had this issue since I have owned it. Starts fine if machine is used every day, otherwise have to boost. Below 20°F will also need boost.
  4. Delmer
    Delmer Senior Member
    Jan 4, 2013
    6,009
    Those measurements are meaningless, you want to know running volts from terminal to terminal, and alternator + to machine frame.
    Below 20 needing a boost can be any number of things, way too complicated to start with that.
    If you leave it sit a week, will it crank the same as the next day, or completely dead? How does it crank the next day after it's run for an hour or more? Like Kshansen said, disconnect the ground after running it for an hour or more, and see if it will CRANK OK a week later, if it won't then the battery is weak, or you have other starter issues. If it cranks the same at first but just doesn't start before the battery tires out, then you have other issues.
  5. daveyclimber
    Aug 3, 2017
    29
    Cottonwood, CA
    There is a battery disconnect. Batteries are disconnected at the end of day via disconnect switch. Battery is dead after sitting more than 1 day. I can also put the battery on a 2amp automatic charge cycle and the charger will never indicate battery is full. I have tried using different chargers with the same results. What about battery cables? What would I be looking for if I check resistance?
  6. TVA
    TVA Senior Member
    May 14, 2018
    1,733
    USA
    Your battery probably shorted or Negative cable rubbed through somewhere and touching machines frame before battery disconnect.
    One wire alternator without diode sometimes can do same thing.
    Actually I’m not 100% correct - incorrectly wired alternator can do this, in case of improperly functioning battery disconnect or negative cable touching frame before disconnect.
    Alternator designed to get excitement current from ignition switch jumped to B+, either at alternator +, battery+ or somewhere else.
  7. Delmer
    Jan 4, 2013
    6,009
    It doesn't matter if there's a disconnect. remove one cable from the battery, and see if it will start the next day. We're trying to see if the battery will hold a charge when disconnected from the machine. Or replace the battery...
  8. TVA
    TVA Senior Member
    May 14, 2018
    1,733
    USA
    You can do simple parasitic amp draw test with LED test light ( incandescent will not work with small current draw ), take the negative clamp off of battery post, connect one lead to post another toclamp - if you see the light with disconnect off - you have a draw. You can do the same with multimeter switched to amp reading but most multimeters have fuses 400-500 milliamperes, well if you burn the fuses it will mean you have parasitic amp draw over fuse limit.
    If the battery wet on top and get pretty warm or even hot at the end of the day - it is shorted.
  9. daveyclimber
    Aug 3, 2017
    29
    Cottonwood, CA
    I charged the battery to 13.2V . Pulled the battery this afternoon and it has already discharged to 10.8V just laying on the ground. Seems like the battery is junk.
  10. willie59
    willie59 Super Moderator
    Dec 21, 2008
    12,479
    Service Manager
    Knoxville TN
    No argument with this one. I wager if you put a load tester on it that it would quickly go wah wah wah wahhhhh
  11. Paul Council
    Paul Council Senior Member
    Oct 12, 2018
    334
    Somewhere
    Sounds like a parasitic draw. Test your negative lead like you have earlier when found voltage on it. Then start pulling fuses one at a time until you see the voltage go away. What ever that fuse is protecting is draining your battery.
  12. thepumpguysc
    thepumpguysc Senior Member
    Mar 18, 2010
    5,347
    Master Inj.Pump rebuilder
    Sunny South Carolina
    Lol.. THATS how "I" find them too Paul.
    I figured he had a dead battery at post #5.. if u have a disconnect, that means there isn't a draw?? the battery is discharging itself..??
    Its funny how "more information" comes out the more they write..
    Post #5 should have been included in post #1..
  13. daveyclimber
    Aug 3, 2017
    29
    Cottonwood, CA
    Thanks for your help guys. I do have a cable that is in bad shape also. The insulation has been oil soaked and swelled. Looks like i had a little fire in the machine also. Building new cables and then I will install the new battery and give it a whirl.
    Vetech63 likes this.
