Wastepro
Hey Ya'll, Hope everyone in the Southeast is enjoying the dry weather and able to get out and start making some.
I've got a Cat It24 F Serial 4NN00391
The starter stays engaged after startup. If I cut the electric off at the master switch then the starter disengages and the diesel motor continues to run. I can then shut the motor off at the fuel solenoid. I tried disconnecting the key switch and then replaced the starter relay with no fix on either. Have electric diagram thanks to the wonderful Nige from a previous issue. Thank you Nige.
Just not sure where to go next .
