Starter Solenoid?
Brendon Benton
Benson, AZ
Substation Engineer
Hello all,
Would anyone happen to know where to starter solenoid is on a case 9020b? All I found is a damn battery relay and of course the starter. Any help would be appreciated.
uffex
Lincoln UK
Admin
Good day Brendon
Give us a snap of it chance are some one will recognise the make and source.
Kind regards
Uffex
John C.
I've not seen one where the solenoid wasn't attached to the starter.
RZucker
Wherever I end up
Mechanic/welder
If that one has the gear reduction starter, the solenoid is inside the starter case. Do you get power to the small wire at the starter when you turn the key to "start"?
Those starters are notorious for failures with no warning signs.
John C.
I think it is an Isuzu engine with the standard type of starter.
kshansen
Central New York, USA
does your starter look like this
Don't know about a Case 9020b but that sure looks like the starter on my Sportsters. Basic Nippon Denso starter that any good automotive starter shop should be able to fix or supply replacement parts for. And yes the solenoid is under that gold colored three bolt cover at the bottom that is partial covered by the large wire.
John C.
That's not the unit I'm familiar with in and excavator but hopefully it is correct.
Brendon Benton
Benson, AZ
Substation Engineer
I can take a picture tomorrow. It's on the other side of the ranch. But it is right above the battery relay. Rear left side door where the battery's are.
