Allan L Vanderziel
- Joined
- Oct 2, 2018
- Messages
- 9
- Location
- Merritt Island Fl
- Occupation
- Heavy Equipment independent mechanic
Hi guys this is my first time posting a question on the form's as I've have read a ton of stuff on here. Here it goes!!, I have a JD 644J loader that I'm in he process of splitting it for the repair of the lower center pin. Upper pin seems in good condition, but the lower one is toast on the coast. The 6 bolts are broken off in the frame as well as the upper hole is so wallared out it need to be line bored. I have split a 544 and 524 but this one seems to not allow me to roll the rear engine and frame section?. Is there an accumulator for the rear brakes that I missed? Hydraulic lines and drive line are removed, steering cylinder pins removed, Both upper and lower pin removed. I set heavy duty stands under the front frame section, and tried to move the rear section with my crane but it wont budge??? So what am I missing??. Any help would be most appreciated!!!. Thanks in advance...........Allan
