Southern Spreader information
Mark250
victoria,Australia
heavy equipment technician
Hi all, I am doing some repair work on a "southern spreader"(Australian model) and if any members have access to these machines I was after the information off the id plates of the spinner Hyd drive motors and the conveyer Hyd drive motor
Thank You
Mark
mitch504
Andrews SC
I do a lot with spreaders, but I have never heard of a Southern Spreader. I'll help with anything I can, though.
I googled them out of curiosity, nice website, looks like they offer lots of support even for old equipment. Some of the trucks they put them on made me jealous.
Mark250
victoria,Australia
Thanks for your reply mitch504
I am after spinner motor speed ranges and the torque required to drive them
Also belt feed rates for gearbox sizing and hyd motor sizing info
Thanks
Tones
Ubique
For the spinner Agrispread uses an 80cc motor for each spinner. Flow in cc divided by motor size = motor rpm.Pressure = torque. Southcott and Berendsens have a heap of info on their websites that may help.
mitch504
Andrews SC
Also, the spinners should turn 750 rpm. Both the New Leader and Speedy Spread spreaders that I run have run 750 for years, and it says on Southern's website under Research and Development that they have gone from specifying 1140 RPM to 750, and are getting good results. I sometimes cut my Speedy Spread as low as 250 for game food plots and trails, but for field work both are run at 750. It doesn't take much torque at all for the spinners.
mitch504
Andrews SC
Belt feed rate depends on:
1. the size of your gate opening
2. the density of the material to be spread
3. width of your spread pattern
4. the spread rate desired
All of these factors are required to determine belt speed needed
Tones
Ubique
No wucken furries
Mark250
victoria,Australia
Just talking to a local contractor. He has 6 of these machines and every one has different size motors on the spinners??????????
I will catch up with him early next week to have a look at them and try and figure what i need for this project
Tones
Ubique
The pump sizes could have a fair bearing on the different motors. All the spinners could be doing the same RPM
( edit) when you have a look next week, take note of how the motors are plumbed, in series or parallel. It can be the difference in motor sizes also
Mark250
victoria,Australia
Tones from what I have seen so far when in series the motor cc ratings are about 30 to 35. if any one is interested I will post what info I find next week
Mark
mitch504
Andrews SC
I am sure there will be a speed control valve for the spinner motors.
Yeah, let us know, we're thinking now.
Mark250
victoria,Australia
Hi had a look at two machines this week both the exact same base model
machine #1
Rexroth double pump A A10V045DFR1/52R PUC62N00 45CM3 2600RPM DR250BAR MNR R902400418 S/N60658737
Gearbox motor Eaton 629A (the rest of numbers unreadable)
Spinner motors cant read tags
Flow divider Haldex D series rotary divider 50;50
This is the information off the first machine can you guys help me with understanding the pump numbers. I could not find this pump on the net
The spinner motors are in parallel with a rotary flow divider the disc size is 750 mm Also need help identifying the motors for this as well
Also could not identify the gearbox
Mark250
victoria,Australia
machine #2
Rexroth double pump A21V045DFR1/31R-PRC12N00-S S/N 00275098
45CM3 FD13W15 DR20MPA FR 18MPA
spinner motors are HDM30-61R1-04S3-ODOD these motors are in series
Gearbox is a Rogelberg 5702-M-2 with 2 bolt flange for hydraulic motor I cant identify the motor for the gear box
I need help understanding the pump numbers and to identify the gear box drive motor
Tones
Ubique
Being a Chinese made pump it could be a little bit different..
