curb guy
I’m going to attempt to cut and paste this damn thing. Let’s see if it works......scan.pdf
Awesome! Glad I could helpYes, I got it - Thank you so much. Now I have some work to do !
If it won’t move at all, Make sure your flex plates aren’t broken. They’re two pieces of sheet metal that are bolted together. I couldn’t believe how thin they were when they broke in mine
Any thoughts on what the pproblem could be?
Hi Chris, did you figure out what the problem was? Having the same issue
I had intended to post what I had found but, I forgot....... Oh well, I did finally figure it out. I was digging through all my old manuals and piles of papers and found a factory TSB that outlined how check the shifter lever on the steering column and, that was the problem. So, if anyone out there in HEF land needs to know how check the levers in either an FR-15B or an FR-20B, let me know and I will be more than happy to post the procedures here.
Well I got an fr20b loader older I bought it drove it home washed it drove it to my bosses about 5 mi down the road parked it came back in about a week later and it wouldn't move you can feel it feels like it wants to go forward but it won't go forward or backwards but somebody had climbed in there and kicked that switch on the emergency brake and broke it so I'm thinking that maybe something to do with them wires any help would be greatly appreciatedLowboy - are you having a problem with a Fiat Allis. I have a FR120.2 and books on it, and have worked on a FR140. Mainly transmission problems(electrical). Let me know if I can help
I would greatly appreciate it cause it's been a year and it's a 9000 dollar flower pot lolMy FR120 would try to move in forward and reverse but you had to give it full throttle and it could not load itself on a trailer. When you shifted from 1,2,3, you could feel it doing something but no real change. I downloaded the troubleshooting guide that was on post 42 and it looks like the shifter circuitry is very similar to mine, so maybe this will help.
Mine had 1 of the 5 solenoids on the valve body go bad. Basically it was stuck in 4th gear electrically no matter what gear the shifter was in, although, inside the transmission there may have been way more going on. On mine, the solenoid that went bad is used in every gear For and Rev, except 4th thus it gets worked the hardest - it even stays on in Neutral, it only turns off in 4th, so now when I let mine warm up, I put it in N 4 so that all solenoids are off. Mine has parking brake toggle switch which put the trans in N and releases(turns off) electric solenoid that sets a brake.
The FR140 I used to work on, had a diode go out in one of the diode blocks. It was stuck in third but would still go For and Rev, and did some other weird stuff. Dealer techs could not figure it out or get the diagram (idiots). I eventually got the diagrams and started tracing and testing - then figured out that the diode blocks were not on the diagrams. They are part of the kick down and reverser option (buttons on the joystick) and were nowhere on the diagrams. I opened the diode blocks, cut the diodes off the terminals to test them correctly, found one bad one, Radio shack had a 27 cent diode - soldered them all back in to the block - DONE. After about three days of wire tracing and research. They wore that machine completely out over the next ten years.
It had a ZF transmission and mine has a Clark.
I could study a little on the info for the fr20b if you need me to help you more.
