So you can learn from my dumb mistakes
Discussion in 'Dozers' started by Sturgill, Oct 15, 2019.
  1. Sturgill
    Sturgill Active Member
    Nov 2, 2016
    27
    Owner/operator
    Kentucky
    I have a D5K, needed a bigger dozer for a job I had. Rented a D6T. (1st time in one). Had trouble starting after using it for 3 days. Turn the key everything lighted up but nothin to the starter. Frustrated, I called CAT and they sent a service guy. Gets in machine and try to start, nothing. Looks a parking brake, engages it and machine starts... Needless to say I felt like an idiot. Oh well, I can laugh about it now.
    Tenwheeler, CM1995, DMiller and 2 others like this.
  2. thepumpguysc
    thepumpguysc Senior Member
    Mar 18, 2010
    4,985
    Master Inj.Pump rebuilder
    Sunny South Carolina
    But doesn't it pizz u off just a little that they couldn't run thru a small diagnostic on the phone 1st.??
    Glad its running..
    Tenwheeler, DMiller and funwithfuel like this.
  3. grandpa
    grandpa Senior Member
    Oct 16, 2009
    1,734
    northern minnesota
    Was there an operators manuel somewhere in the cab?
  4. DIYDAVE
    DIYDAVE Senior Member
    Feb 18, 2007
    1,520
    MD
    BTDT, with alla the safety switches on today's equipment, happens alla the time!;)
    Ronsii and DMiller like this.
  5. Nige
    Nige Senior Member
    12,245
    It got to the stage on the last job where we even trained our Dispatchers to ask "Is the Park Brake Off.?" when some whiny operator called in with a plaintive "My tractor won't start....."
    DMiller likes this.
  6. wornout wrench
    wornout wrench Senior Member
    Feb 17, 2012
    505
    Retired Heavy Duty Mechanic
    Campbell River, BC, The Left Coast of Canada
    Don't feel bad Sturgill.
    I spent way too many years as a field mechanic. I lost count of how many times I was sent out to start a piece of equipment and found it to be something as simple as putting it in park, applying brake, turning the isolation switch on.
    Definitely not an exclusive club.
    sled dog and DMiller like this.
  7. seville009
    seville009 Well-Known Member
    Apr 5, 2008
    91
    CNY
    Used to be the “computer guy” many years ago for a local company with many branches. Learned to ask people that called with problem “is it turned on”, “is it plugged in”.....many times the answer was “no”.
    DMiller likes this.
  8. kshansen
    kshansen Senior Member
    Mar 11, 2012
    7,229
    Central New York, USA
    My first wife spent several years as an AV Tech at a High School near here. This was back in the dark ages when the class rooms still used 16mm film projectors. More times than she could count a teacher would call down to her office complaining about a projector not working so she would always ask if it was plugged in and most of the tiime that was the solution.
    Then this one time when she asked that standard question she go a rather indigent reply "YES IT IS! I WANT THIS FIXED RIGHT NOW!!" So Ellen made a beeline for the classroom. She walks in the room and takes a look at the projector on the roll cart. Sure enough the projector was plugged into the power strip on the cart but the cord from the power strip was neatly rolled up on the bottom of the cart! She reached down and grabed the cord and plugged it into the wall socket fliped the switch on projector and turned and started out the room and the students simultaneously gave her a round of applause!
    check, CM1995, Ronsii and 1 other person like this.
  9. Queenslander
    Queenslander Senior Member
    Apr 5, 2009
    834
    E stops have been the cause of some anxious times for me in the past.
    Working a newly bought machine, on the lookout for anything abnormal and it suddenly dies, frantically check fuses, circuit breakers, batteries, wondering how much it’s going to cost to get someone out to spend hours diagnosing some obscure electrical fault.
    Go for a walk around the machine and discover that a branch has swatted the e stop.:rolleyes:
    Nige and sled dog like this.
  10. Mark250
    Mark250 Senior Member
    Aug 30, 2015
    883
    heavy equipment technician
    victoria,Australia
    And don't forget the ground level shutdown swich
  11. DMiller
    DMiller Senior Member
    Feb 22, 2010
    5,902
    Retired
    Long time OLD Story, Utility crew working a substation installation job calls dozer quit moving cannot spread rock, need service call. They send ME. Old IH Drott, never seen one this SMALL, get on board, fired right up, feel it drop into range(Powershift), release parking dog on foot brake and off to spreading rock. Foreman comes running out of station shack with operator(lineman) asks what I fixed, stated NADT, explained as I got off and re-engaged foot brake dog, operator looks at me and goes "What's That"? I look machine over all is good, even oil not cooked YET, even has been run with brake partially engaged until got hot enough to bind up, brake wasn't even out of adjust yet.
    I go back to shop, boss is furious AT ME, sends another grunt up with 28 gallons of Hystat Oil and does a filter/oil change as was "Burnt", I saw the oil come back, looked better than what was sent up.
    Nige and check like this.
  12. check
    check Senior Member
    Apr 1, 2012
    708
    in the mail
    In the age of electronic gadgetry, it seems everything has "special procedures" that must be followed. Often these procedures defy logic. Not knowing them is not indicative of stupidity, but perhaps designing equipment logic that defies logic is pretty stupid, as are all the "international symbols" they force down our throats when plain English would be so much better.
  13. DARO
    DARO Well-Known Member
    Sep 8, 2014
    174
    Mechanic
    Duluth MN USA
    Iv hurt a few feelings with my over the phone no start diagnose check list. Me " is the park brake set" operator " YA" me ok release it and reset it right now while im on the phone................... operator " ahh it just started"
    DMiller and kshansen like this.
  14. kith
    kith Active Member
    Oct 6, 2009
    43
    iowa
    When going on service calls for machines that won't start people get ticked when you ask if it has fuel in it, but have seen them out of fuel quite often.
  15. Sturgill
    Nov 2, 2016
    27
    Owner/operator
    Kentucky
    Sadly yes, with a call out to set the parking brake....☹️
    DMiller likes this.
  16. Ronsii
    Ronsii Senior Member
    Jun 26, 2011
    1,855
    s/e Heavy equipment operator
    Western Washington
    Yeah.... but I mean... who ever reads the manual? ;)
    DMiller likes this.
  17. Nige
    Nige Senior Member
    12,245
    Isn't that the LAST thing you're supposed to read..? :confused::confused:
    DMiller and Ronsii like this.
  18. Welder Dave
    Welder Dave Senior Member
    Oct 12, 2014
    2,575
    They should change the name from manual to automatic... so you have to read it before you operate the machine.
    DMiller likes this.
  19. sandy
    sandy Well-Known Member
    Aug 16, 2007
    52
    diesel mechanic
    As a Service tech I enjoy these calls
    Somthing simple and easily fixed
    Bit of embarrasment, no stress and on to the next one
    donkey doctor and DMiller like this.
  20. ianjoub
    ianjoub Senior Member
    Jun 22, 2018
    460
    Homosassa, FL USA
    Bit of embarrassment, no stress, SUBMIT A BILL, and on to the next one.
    DMiller likes this.
