There is a mile of gravel between the drive way and the high way. This year i will need to plow it some so the girls that take care of my parents can come and go. I have 3 tractors no cabs . I have a good home made front blade that was on a 3020. It gos back to the draw bar and has a cylinder in front so what when its raised the frame running to the drawbar dosent raise. I would like to mount this on a truck because they have heaters. The truck i would like to use is a 1963 f600 and its frame horns are light so i would make a mount under the frame behind the cab so i could use the draw bar setup or should i mount it on a tractor and rig up a heat houser the blade is a little big for my tractors.
