Snow Plow 2013
Curbster
Nelson, B.C.
Prime Digger on Dog Hill
Well, it's been a slice, and I'm slowly learning about these new-fangled machines, but don't know too much yet! Not that I ever did, but.....:pointheadSide view.jpgSteering,gears,tilt,articulation.jpgWing.jpgBlade controls.jpgLeft side.jpg
Curbster
Nelson, B.C.
Maybe a few more. Especially the area where there used to be a steering wheel!No steering wheel.jpgLights,wipers,heater,etc.jpg
Curbster
Nelson, B.C.
We use type of cutting edge for snow and ice only. It really cuts through the ice and hard packed snow if you roll the main blade downward a bit. Also leaves enough gravel and sand on the road - where it has been previously sanded, for pretty good traction. They don't work very well for gravel grading though. Probably lots of different applications for different types of grading and I'm sure some other operators have used them in different situations. They last pretty good if you don't use excessive down pressure. I don't use "float" very often as you can go "diving" in a hurry when you hit the softer spots!:)
Curbster
Nelson, B.C.
Both wing and main blade have doubled up edges on them. Not single segments but two lined up together, so each blade has four pieces instead of two. This really gives them extra life - depending upon operator usage, as you can still burn them out pretty fast if you get too aggressive. This company maintains a 12km ski hill road that becomes very glazed with traffic and excessive braking by the whiz kids who consider it to be another downhill racetrack. These blades leave traction material on the road instead of a smooth flat blade result.
