archibaldtuttle
I have a compensator that is bolted directly to the pump on this boom lift and I'm trying to figure out if it is maladjusted, worn spring, etc. or I have a bad pump.
the adjustment described as the pump main is already bottomed. Been that way since I before I bought it in 2014 and been running we the people for 4 years modest hours. Functions across board slowed or have been erratic last couple months and the deadheaded main pressures is only showing 1400 PSI which is half of desired.
manufacturer says it is probably pump but tach i know who is remote so can't come look says he always suspects compensator first. this is a 2006 unit with less than 2000 hours on it. I have no reason to suspect it was run low on oil or clogged filter or compromised in anyway although i have only had it for 4 of its 12 year life.
It appears although i don't have an internal schematic that the compensator design diverts flow that does not pass through the compensator orifice to return piping to the hydraulic tank. There are two adjustments on the assembly, one that manufacturer claims adjusts operating pressure and that is already bottomed. The other is the 'compensator' adjustment and i haven't cracked the cap off that yet as i'm trying to better understand what i'm dealing with.
The pump itself is a proprietary eaton made for snorkel. its possible i could take it off of there and spec it and see what is available that could replace it but don't want to replace it unnecessarily and i've got excavators with 25 year old pumps going strong so I'm hesitant to indict the pump with better diagnosis.
Any help anyone who has worked on one of these can offer much appreciated. And/or experience, if i just pull the pump and compensator off can i take them to bench tested?
thanks,
brian
thanks,
brian
