Snorkel tb60 issues
Discussion in 'Forklifts/Telehandlers' started by Snorkel issues, Sep 4, 2019.
  1. Snorkel issues
    Snorkel issues Active Member
    Aug 9, 2019
    34
    Tennessee
    When you crank it throttle pulsates press pedal and doesnt throttle up. Everthing moves slowly. It's the ford motor duel gas fuel. Sent to a place they said throttle solenoid bad. Changed it then worked fine moved across parking lot blew the solenoid said bad wire somewhere. Any one have ideas on this.
  2. BillG
    BillG Senior Member
    Mar 26, 2009
    364
    S. Wisconsin
    Which style solenoid, 2 wire or 3? If three then you are working off the pull in winding only and this overheats and blows out quickly when used as a continuous duty. Serial number and which throttle controller that it has would help. Some had a very simple throttle circuit with no controller and others were more complicated with multiple step throttle governing.
  3. Snorkel issues
    Aug 9, 2019
    34
    Tennessee
    Were having trouble even finding it on machine. If it's the part I think I've found its three.
  4. Snorkel issues
    Aug 9, 2019
    34
    Tennessee
    Jas 3 screws on back and then looks like threads goin towards motor with nut on it. Does this sound right
  5. Snorkel issues
    Aug 9, 2019
    34
    Tennessee
    And our machine has the computer
  6. BillG
    BillG Senior Member
    Mar 26, 2009
    364
    S. Wisconsin
    Machine serial number? A picture of the solenoid and controller would help. If it's original it is probably a 2 wire solenoid if it is updated/retrofitted it could be anything.
  7. Snorkel issues
    Aug 9, 2019
    34
    Tennessee
    Tb a6orfo...and not sure what it looks like cant find it on machine. I'm worried guy told us some b.s
  8. BillG
    BillG Senior Member
    Mar 26, 2009
    364
    S. Wisconsin
    That serial number does not match anything I have. Are you sure it's a Ford and not a GM?
  9. Snorkel issues
    Aug 9, 2019
    34
    Tennessee
    Oh I gave numbers on lift. Let me get with uncle. It's his lift I'm just tech support lol. That's why I'm sucking at explainin .
  10. Snorkel issues
    Aug 9, 2019
    34
    Tennessee
    Oh and I got to thinking. He might have meant the throttle body itself. Could that be possibl .
  11. Snorkel issues
    Aug 9, 2019
    34
    Tennessee
    I'm sure he meant throttle body because ever were I check says machine shouldnt have a solenoid
  12. Snorkel issues
    Aug 9, 2019
    34
    Tennessee
    But motor is ford for sure
  13. BillG
    BillG Senior Member
    Mar 26, 2009
    364
    S. Wisconsin
    Again without knowing the serial number it is just a guess, but with a throttle body it will be a later one rather than one with a carb. If the TB motor is failing make sure the ecm is ok before installing a new one. They operate via a pwm signal from the ecm and if the output from the ecm is shorted it can destroy the motor.
  14. Snorkel issues
    Aug 9, 2019
    34
    Tennessee
  15. Snorkel issues
    Aug 9, 2019
    34
    Tennessee
    We change ecm already. Would a bad new ecm blow throttle body
  16. Snorkel issues
    Aug 9, 2019
    34
    Tennessee
    Fuel injected
  17. BillG
    BillG Senior Member
    Mar 26, 2009
    364
    S. Wisconsin
    There is a service bulletin that covers these issues from FPP (Ford Power Products), I will see if I can find it.
  18. Snorkel issues
    Aug 9, 2019
    34
    Tennessee
    Thanks. Appreciate all the help.
  19. BillG
    BillG Senior Member
    Mar 26, 2009
    364
    S. Wisconsin
    It is FPP 194-306, the bulletin covers troubleshooting the fuel and electronic systems on that engine. The following url is from Snorkel and gives a breakdown of the components and locations.
    https://documoto.digabit.com/ui/document/618727
    You can (or should be able to find) the FPP 194-306 on the net by Google. I don't have it in electronic form.
  20. Snorkel issues
    Aug 9, 2019
    34
    Tennessee
    I found the one I could google. I ca t get into the other. Username and password required
