randy lee hoeft
I'm stumped. i changed filter ,cleaned tranny screen had sludge in pan not much for filing, put dextron !st 4 gallonHi Tom, Transmission fluid is just Dexron, regular ATF. That transmission will always check somewhat overfull with the engine off as the torque converter drains down into it. It's supposed to be checked running. If it's low you add fluid into the converter slowly and wait for it to show up at the transmission check plug. If it's overfull by much, machine will be sluggish as you've found. This usually means that hydraulic oil is transferring from the hydraulic system through one of the pumps. As long as it's not too severe you can run a long time that way - just drain the excess occasionally and keep an eye on hydraulic level. Michigan allowed ATF in the Hydraulic system so we always ran that way and it avoids mixing two different oils.
then used 15 20 min wont just stops ,then went change fluid again and put 30 weight, worked about 20 min and stopped pulled backwards 2 feet started working again , need help please
