I’ve got a question/looking for experience in articulation on a Road grader, with a Rome sloper attached.
The grader, a John Deere 770D, has articulation cylinders that are leaking/bypassing, causing the machine to articulate left and right, when turning. I found the articulation cylinder lines capped off, due to adding the sloper and needing the valve bank to run it. I’m getting the cylinders repaired and ready to install. Given the mounting design of the Rome sloper, articulation is not usable, but the cylinders are still vital in keeping the machine in-line. My question is are there any options for doing away with the articulation cylinders?
