Skytrak loss of hydraulics
Discussion in 'Forklifts/Telehandlers' started by Dillon0608, Mar 10, 2020.
Tags:
  1. Dillon0608
    Dillon0608 Member
    Mar 10, 2020
    12
    Arkansas
    I have a 2001 6036 skytrak I drove it about a quarter mile and lost all drive and hydraulic functions motor runs and drive line turns to the transmission. Any suggestions on what to check first
  2. Txhayseed
    Txhayseed Well-Known Member
    Dec 23, 2019
    69
    Texas
    Take the engine covers off and there is a quick connect to check pump pressure. Put your gauge on it and see if you got pressure out of your charge pump.
  3. Txhayseed
    Dec 23, 2019
    69
    Texas
    Sorry not engine covers. Your transmission covers...
  4. willie59
    willie59 Super Moderator
    Dec 21, 2008
    12,414
    Service Manager
    Knoxville TN
    Are you certain that drive line from engine to transmission is turning when under load?
  5. Txhayseed
    Dec 23, 2019
    69
    Texas
    Willie59 made a good point Check your drive line.
  6. Dillon0608
    Dillon0608 Member
    Mar 10, 2020
    12
    Arkansas
    Yes it is turning when trying to use hydraulics or drive
  7. Txhayseed
    Dec 23, 2019
    69
    Texas
    Next step would be to check your hydraulic pressure on the test port. See what your reading there...
  8. Dillon0608
    Dillon0608 Member
    Mar 10, 2020
    12
    Arkansas
    I’ll do that tomorrow
  9. tractormech
    tractormech Well-Known Member
    Feb 19, 2015
    126
    florida
    Post your serial number too-that can help troubleshooting.
  10. Dillon0608
    Dillon0608 Member
    Mar 10, 2020
    12
    Arkansas
    Serial number 15539
  11. tractormech
    Feb 19, 2015
    126
    florida
    Ok thanks. Will it steer?
  12. Dillon0608
    Dillon0608 Member
    Mar 10, 2020
    12
    Arkansas
    No
  13. tractormech
    Feb 19, 2015
    126
    florida
    Okay. There's a splined coupling on the shaft that hooks to the hydraulic pump. It may be stripped since you say you have no hydraulic functions at all. That would be my first thing to check after you verify no hyd. pressure.
  14. Dillon0608
    Dillon0608 Member
    Mar 10, 2020
    12
    Arkansas
    No hydraulic pressure
  15. Paul Council
    Paul Council Senior Member
    Oct 12, 2018
    252
    Somewhere
    If you lost all hydraulics and drive then the flex plate between the torque converter and flywheel has failed.
  16. Dillon0608
    Dillon0608 Member
    Mar 10, 2020
    12
    Arkansas
    The drive line from the motor to the transmission is turning and the spines on the hydraulic pump are good
  17. Dillon0608
    Dillon0608 Member
    Mar 10, 2020
    12
    Arkansas
    No but I will
  18. tractormech
    Feb 19, 2015
    126
    florida
    I agree with Paul-check the flex plate-that would explain total loss of drive and hydraulics
  19. Dillon0608
    Dillon0608 Member
    Mar 10, 2020
    12
    Arkansas
    But wouldn’t the drive line between the engine and the transmission stop turning
  20. willie59
    Dec 21, 2008
    12,414
    Service Manager
    Knoxville TN
    Not necessarily. Under no load, all things in neutral, even a busted flex plate would cause enough friction to spin the shaft, but it wouldn't be spinning at the rpm being delivered by the engine. Likewise, even though shafts would be turning, they wouldn't be turning fast enough to develop any work.
