Skidloadertech
Hi, I have a Skyjack SJ45T s/n 980024 in the shop. It’s driving us crazy. It has a Deutz 2011 engine. The customer had it out on rent and the operators ran it out of oil and toasted the engine. He found another rebuilt 2011 engine that is a newer version but technically the same. A shop swapped it out for him , they swapped out all the sensors, engine harness, fuel actuator, everything that tells the ECM anything. It has never started since.
If the fuel rack actuator is removed, and the throttle is run manually it runs great. So we know that we have an issue with the electronics. The thing is, all the test check out. The actuator ohms out correctly, the wiring harness ohms out. We installed a new actuator and a different ECM from a twin machine. It must be something in the wiring harness that we are missing.
If anyone has experience on these machines please chime in here. I NEED Help
