Skidder 525B winch removal.
tift104
Ga
Ok guys, I'm planning on removing the winch on a Cat 525B. There is a small 1/2 hose that goes into some sort of control valve bolted to the winch. This hose has constant flow when the machine is running. Then there is a larger maybe 3/4 inch hose coming out the bottom of the winch.
I'm assuming the larger hose is a return line since there is a flow of oil that comes out where it connects when the machine is running.
When I remove the winch should I connect the two hoses together with a fitting and bypass the winch totally? Im not sure the winch works since the electrical and shaft were unhooked when I bought the machine.
This is going to be a spray tractor and I need the tank to sit as close to the frame as possible and removing the winch will bring it down another 8 inches.
What would your recommendations be to remove the winch?
Thankyou for your advice.
Mike L
Texas
Self employed field mechanic
Unhook and cap them. Unless the hydraulic circuit is activated the. You shouldn’t have any high pressure and since you mentioned that the electrical is unhooked then I think you’ll be fine
tift104
Ga
Thanks Mike. That was my original plan but I guess I started overthinking it. The button may of been pushed when I took the hose off.
John C.
If you are not using the circuit you will likely have to remove the pump that feeds the upper line.
Lonnie Varner
Oakland Oregon 97462
