cooberb78
I still can't get my machine to track properly. When I check a1 and a2 they don't have but about 200psi when travel valves are moved (cable operated). Left travel works sometimes and I get pressure increase at pump. If I hold the right pedal down after a while it will kick in at full speed and I get pressure increase at pump. Have went through book on all pressure measurements for all functions. All pressures are spot on except travel. Measured at pump,T in at top of swivel and T in at right motor no pressure
