Single double or triple axle roll off?
CBM8430
Summit, NJ
I’m considering purchasing a roll-off company in NJ. The seller tells me that his single axle cable lift International trucks are able to haul dumpsters with 10 tons of weight in them. Figure 2.5 tons for the dumpster and you’ve got potentially 12.5 tons of weight on the truck. I am concerned that is too much weight for a single axle. Am I right to be concerned? Thank you for your replies.
10 tons total weight including the bin maybe but I still doubt. I imagine the apparatus to lift the bins probably weighs a bunch too. I had a tandem come to haul away an old garage and I think the driver was out to lunch. He said he could only carry 9 tons in the bin.
CBM8430
Summit, NJ
Thank you. So you’re thinking a double axle would be required? I am thinking that there are tire to pavement surface area considerations rather than mechanical. Many of the larger hauling trucks I see have very wide front tires also.
CBM8430
Summit, NJ
Was looking the through some truck classifieds and looks like rear can handle about 10-11 tons per axle, so I am leaning toward a double axle. I feel like triple axle would be overkill and increased maintenance on the truck with the lift mechanism, but that single axle wouldn't be enough.
mowingman
North Central Texas
Retired
Keep in mind how the number of axles is going to affect the overall size of the truck. I was going to get into the dumpster hauling business, until I looked at a few trucks. They were so big, they would never be able to operate in the places I would need them. Those rigs can get looong in a hurry.
IceHole
AK
A single dual truck is GVWR of what, 30kish?
Truck probably 12-15k, so maybe 10 tons load if evenly balanced.
That sounds about right if the bin and lift are included. Depending what you're hauling it can be easy to overload especially if the customer loads it. They will just fill it and if it's too heavy figure it's your problem. Also if they don't want to pay for a 2nd bin they'll stuff everything into 1 bin. A tandem gives a lot more leeway if the bins aren't too big.
CBM8430
Summit, NJ
Thank you everyone for your replies. I got too busy to check this for a few weeks and in that time, I got a wealth of information! I'm seeing some tandem trucks with GVWR of 85k lbs. More than enough to handle my needs.
cfherrman
Hays, Kansas
Ive seen some oilfield trucks gvwr to that and they only think I can think of is they thought they needed the truck rated for the trailer as well when they tagged it. So idk
My rig is a twin steer and I think I could go up to 74k
crane operator
sw missouri
I have no idea what New Jersey bridge law allows, but I seriously doubt it’s 85,000 on three axles
They do typically spec roll off trucks with double frame, and I could see 46k rears and a 20k front.
CBM8430
Summit, NJ
Just checked NJ regs (https://nj.gotpermits.com/njpass/Permits/DownloadStateAttachment?index=2) based on crane operator's tip and source I used confuses me a little bit. Page 12 seems to indicate a max allowable weight of 22.4k, but then page 14 says 34k. If I read this right, then the max GVWR for a tandem roll-off would be 56.4k. So I think that's my answer. Even if it's a GVWR of 44.8k, it's still way more than I would need.
cuttin edge
NB Canada
Finish grader operator
12.5 metric tons on a single axle is too much—you’ll wreck the truck. I’ve been through this myself, and I ended up using the single-axle truck strictly for residential containers, which are lighter. To make sure I don’t mix up the trucks and don’t send the single-axle truck on heavy construction jobs, I got the dispatch software from. It helps me quickly assign orders to the right truck.
He's American, so he's talking old tons not metric. But still 11.3 metric. This is a thread from 2023
That was a spammer CE. Only saying that so your post is not an orphan with no context.
