Should I take on this project? 50s Cat D4
Discussion in 'Dozers' started by Lumberjack Matt, May 15, 2021.
  1. Don Shilling
    Don Shilling Well-Known Member
    Aug 10, 2019
    142
    Retired, multi occupation
    Texarkana, Texas
    At least you are in a positive frame of mind. Not counting my D21, most of my used equipment have been "learning experiences" to get running again! My current project is an 8N Ford that I should have spent my money on a good running one. But, I'll know just what condition its in when I get it finished.
    DMiller, Sam1734 and 56wrench like this.
  2. Sam1734
    Sam1734 Well-Known Member
    Mar 1, 2020
    66
    Not trying to rob a post here, but I have a 801 power master with the 177 ci engine that is basicly similar to the 8N and I have issues with that thing too. It is my nemesis. It has literally turned me against gas burners for farm/heavy equipment.
    DMiller likes this.
  3. Bluox
    Bluox Senior Member
    Jun 20, 2010
    1,534
    WA state
    Since your this far in take the top plate of the clutch housing and see what kind of disaster is going on in there .
    Also check hyd . pump is not froze up.
    Bob
    Lumberjack Matt and DMiller like this.
  4. Lumberjack Matt
    Lumberjack Matt Well-Known Member
    May 15, 2021
    48
    Oregon
    Drained and removed the hydraulic pump (thing is way heavier than it looks), no water in the fluid, and the valves appear to be good. Some grit came out, but doesn't look as bad as I thought it would be. Here are the leftovers from the bottom of the tank.
    Drained the clutch and flywheel compartments. Most concerning stuff was in there. Not much water, a lot of sludge, and some metal pieces. They look like gear teeth, but too small to be flywheel teeth. Since I'm pulling the engine, I'll get a better look at this later.
    Transmission fluid looked good. Clearly had a little water mixed in, but I've seen way worse. No grit or gear teeth in the bottom. Big relief.
    Steering clutch compartment full of water and oil. At this point it's clear I'll have to replace the steering clutches... was already kind of planning on this though because of how the levers feel when I pull them.
    Final drive oil was pristine.
    I filmed all the drainings here. Skip to 13:06 to see the deluge of water from the steering clutch compartment.
    Next up is pulling the radiator and injection pump. I've only snapped one bolt so far...I know it sounds silly, but this is my #1 gauge of how bad a project is. There's nothing that slows down progress more than a snapped bolt.
    Not sure if I should keep posting in here, don't want to keep bumping this thread and spamming the forum and annoying everyone. Let me know if I should stop, otherwise I'll keep posting updates.
    Gasnoil, doublewide, Jonas302 and 3 others like this.
  5. Welder Dave
    Welder Dave Senior Member
    Oct 12, 2014
    6,571
    Keep posting your progress, everybody likes to see old iron come back to life.
  6. Sam1734
    Mar 1, 2020
    66
    Absolutely agree!!!
    Lumberjack Matt, 77Ford and DMiller like this.
  7. Don Shilling
    Aug 10, 2019
    142
    Texarkana, Texas
    This is extremely interesting! It lets people know what to expect with old machinery. AND, lots of pics!
    DMiller, Sam1734 and Lumberjack Matt like this.
  8. Shivan Dookeran
    Shivan Dookeran Active Member
    Feb 18, 2021
    42
    Trinidad ,west indies
    love the dedication u puttimng on .. keep up the work bro
  9. Lumberjack Matt
    May 15, 2021
    48
    Oregon
    Got the radiator and injection pump removed. Also opened up another inspection cover on the crankcase. It just seems that there is this grit/gravel all throughout the engine. It has the consistency of something you would see at the bottom of a creek bed.
    Here is the output of the filter tower to the fuel rack (I believe this should be filtered fuel). The o-ring here was completely cracked in half, so that's probably the source of all the diesel in the crank case:
    The fuel rack itself looks like it's in good condition:
    Here is the inside of the inspection cove. Rods completely covered in very loose scale. Scale also sprinkled all over everything:
    It's very odd. Nothing is seized or corroded through, but everything has this rust/grit completely coating it. I feel pretty confident that I can get this engine running. It will just require a complete disassembly and cleaning.
  10. FarmWrench
    FarmWrench Well-Known Member
    Oct 13, 2013
    121
    Table Potato farmer
    Chaffee NY
    Keep posting. I'm considering going down the same road with a D4d.
    56wrench, Sam1734 and DMiller like this.
  11. Lumberjack Matt
    May 15, 2021
    48
    Oregon
    Will do! Also trying to record most of it and putting it on youtube (mostly so I remember how everything goes back together).
  12. Lumberjack Matt
    May 15, 2021
    48
    Oregon
    Pretty sure I have everything detached and all the geometries right to pull the engine without breaking anything. I'll find out tomorrow!
    PXL_20210712_024004748.MP.jpg PXL_20210712_023728167.jpg PXL_20210712_023653772.jpg
    56wrench, DMiller and Sam1734 like this.
  13. Puffie40
    Puffie40 Well-Known Member
    Apr 6, 2010
    171
    Southeastern B.C.
    That grit is 'rust blooms' - Those tend to appear on iron in very humid environments. Given the oil pan was full of water, that is perfect conditions for creating a sauna. A wire brush will knock them down, and once you get the motor running, the oil will prevent the rust from continuing.
    It's a good call to tear down the motor. Those rust blooms would accelerate the wear inside the engine.
    Not sure what the teeth you found in clutch housing might be from. The steering clutches have small teeth on the plates, but I don't know if the main clutch had any teeth aside from the splines on the input shaft.
    59 North and DMiller like this.
  14. Lumberjack Matt
    May 15, 2021
    48
    Oregon
    Got the engine out and oil pan off. Actually looks better than I was expecting.
    Lot of surface rust on the rods and crank, but bottom end of the cylinders are pristine (ignore my finger print smudges).
    If I had to guess, the hangup with it fully rotating is the camshaft. That thing is rough.
  15. Lumberjack Matt
    May 15, 2021
    48
    Oregon
    Here is the inside of the oil pan, in case anyone wants some chocolate pudding.
  16. catman13
    catman13 Senior Member
    Aug 22, 2011
    398
    oregon usa
    that cam shaft is toast
    56wrench and DMiller like this.
  17. DMiller
    DMiller Senior Member
    Feb 22, 2010
    11,911
    Almost Retired
    Yeah no polishing that one.
    56wrench and Sam1734 like this.
  18. Lumberjack Matt
    May 15, 2021
    48
    Oregon
    Yeah I've already started looking into finding a new one. I'm gonna dip it into some evaporust just to see how bad it is. Hoping to get it out tonight.
  19. Don Shilling
    Aug 10, 2019
    142
    Texarkana, Texas
    Camshafts can be reground. Might be worth looking into.
  20. Lumberjack Matt
    May 15, 2021
    48
    Oregon
    Cam gear won't be winning any beauty pageants either.
    Whoever invented evapo-rust, I'm about to put his kids through college.
