Shockit! Tool to loosen and disconnect hydraulic hoses
oceanobob
oceano california
general contractor
For "some reason" I bought a used small 4000# CTL for those little jobs....the undercarriage had some wear and neglect, so it is in the shop along with all the other projects. Getting repaired and adding to the parts bill. LOL
Removal of the drive motor hydraulic hoses for access was required and we were barely able to loosen them using the double open end service wrenches (tight congestion). Box end or flare nute 'crows foot' was useless, a standard open end crows foot slimmed with a grinder did help.
Then with the magic of the internet, these tools popped up.
Made by LTI Milton they are named Shockit.
Like a box end flare fitting crow foot wrench but no square drive: has a shoulder with a shallow hole that the special point chisel from the air hammer fits into.
There are a couple videos on you tube showing applications. The Milton catalog pg 218 shows the various pns to cover the SAE sizes (LT1920 and LT1920XL). I also noted if the tool is LTI sourced say from Summit, the part number is different (LT1900) and the range of the pieces is more likely in the size I need.
Then this: To make the items more tempting, Milton's air hammer is two directional and can be fitted with a tool that is mfg with a flat end that can for example hook under a lip seal and pull it outta the bore. The slide hammer wont be able to smash the skin on the web between my thumb and hand: so sad to keep the slide hammer on the shelf / in the drawer.
Has anyone experience with these tools? I'm contemplating an order for the LT1900 set and the two way air hammer kit. It is indeed a tough time for the budget, being Valentine's day is imminent.
IceHole
AK
I've cut the hose a few times and used a socket... even had to blow out the fitting with torch once. Not ideal, but made sure to flush it out best as possible before putting it back together
ozarkag
ozarks
We have a shockit kit, only comes out once in a blue moon. And then works extremely well about half the time. If you can line everything up good so the crows foot doesn't pop off. . .
The job you described sounds ideal for it tho
oceanobob
oceano california
general contractor
Recently obtained a set of Shockit sockets, the Kentucky Kicker (short extension assist), but the bidirectional model 855 gun is being replaced by the 955 model. Might be a month or so....
M2Follow
Mike L
Maine
Self employed field mechanic
I’ve never seen that tool before but I have used a crows foot socket on my impact gun where space allow.
oceanobob
oceano california
general contractor
An update .....
Model 955 just recently available per a news release article in a trade magazine....called where I ordered the sockets and they had just recvd pricing - but no stock.....sayeth shipping on Jun 6 but now backordered to the 10th.....
M2Follow
Old Doug
Mo
This is one of those tools if you had a buddy with a kit or could rent them for the once in a while.
92U 3406
Western Canuckistan
Wrench Bender
Picked up the LT1900 kit a couple months back while browsing the truck. Have used it a couple times already and its saved me some headaches and cut down repair times on a couple jobs now.
Definitely worth having around IMO.
