Sorry I'm not a JD expert. Maybe someone else will offer an opinion.I have a 310SJ backhoe and am looking for TM10849 and TM10848 in either printed or pdf format. Thanks much for your kind attention.
Hello Tinkerer,I should have looked closer at that website.
It is in Russia.
Sorry
The web-designer did a good job of faking the JD site.
You're right. I may have to bite the bullet and just think of it like that. On the brighter side, any repairs I may be able to perform myself and outside a JD dealer will pay more than the cost of the book in savings.OEM manuals are expense, but, they are a good investment if anyone plans on doing their own work.
I equate them much like a replacement part. A necessary expense.
TM10849 is available on eBay in like new condition for $249.00. The seller has over a 1000 positive ratings.
I would buy it if I were needing one.
hi Brian , you got any luck getting the manual?You have the 410G service manual?
Don't know if I or anyone else ever responded to you, I've been "On a break" from HEF for a while. This should be the correct pump, travel motor, and final parts sheets for your machine.Hi everyone,
Does anyone have an engine rebuild manual for a S6D95L-1. It's in a morooka MST-1100 that I have with the komatsu branding. any info on final drives and transmission would be helpful too.
Also, has anyone here used "friday parts online"?
Thank you,
Sean
