Saved from scrap
BKrois
Charter Member
Connecticut
Multi purpose
Found out about this 955H recently near me. Had been sitting for 10 years, typical "ran when parked". Some fresh fuel, batteries and a new starter(bendix wouldn't engage) and it fired up. Someone slammed the wrong sprockets on that's on the list. Its a powershift with hand/foot steering
RZucker
Wherever I end up
Mechanic/welder
It happens. Case/Poclain excavators. Order sprockets for a 160, and find out you have a 180 undercarriage. Then you find out the ones you need are no longer available. Torch time. I don't miss that thing at all.
BKrois
Charter Member
Connecticut
Multi purpose
They cut an inch off each of the teeth so it would clear hitting one of the guards. its wants to throw the tracks, they're probably not the right pitch either.
RZucker
Wherever I end up
Mechanic/welder
The sprockets may be the right ones. The tracks are more than likely wrong.
CatGrader
Grader Operator
Good old tracktors them. With a good operator they will still give the new stuff a run for there money. ***~
