05sprcrw
I feel like I am fighting a loosing battle, on trying to figure out why any aux hydraulic attachments will always move on their own. I have singled it down to the female coupler side of the system.
If I start the bobcat and use it there will be no movement of the attachment (like it should). If I energize the aux hydraulics variable flow, it will still be fine, however once I move the attachment the first time it will continue to open (in this case) my grapple. This is pretty annoying trying to keep the brush in the bucket while it keeps wanting to open. It is not like its getting full flow by any means its just creeping up over the matter of 30 seconds for the full range of motion.
Things I have tried, but have not been the answer:
Both new aux valves (stems and coils)
New Aux circuit lockout coil/stem
New aux springs, bushings, caps and seals
New check valve seats, springs and seals
New High Flow solenoid thinking it was not fully staying off/leaking by (high flow deactivated when I bought the machine)
If I unplug the aux coils after it has started its creeping issue, it will continue so I believe it has to be something mechanical within the circuit. I have not tried unplugging the high flow on/off valve yet.
All of these things have been over the last year or so, but its time where I am needing the grapple and tree shear a fair amount and now am really determined to get to the bottom of this issue. I am going to flip my couplers on the grapple for now so it will at least power close but its not idea for getting out and loading branches and things in the grapple while cleaning the yard up from the winter and trimming trees.
I am really at a loss for what to try next, some thoughts are:
New right stick control handle (grasping, but don't think its the issue)
Try a new aux spool (other looks fine no marring)
Remove aux spool and try to install it the opposite way (service manual didn't make it sound like it mattered which way it went back in, and appears the same each way)
Possibly damaged main valve body (hope not,sounds expensive)
The hydraulic circuit diagram in the service manual the only other thing in the female coupler circuit that I haven't looked at would be the relief valves, but since it builds pressure I don't think those would cause this issue.
Any and all ideas/help would be greatly appreciated.
